O que você precisa
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Using a Philips screwdriver #0, remove the screw securing the SSD.
Lift the end of the SSD slightly and pull it straight out to remove it.
Um agradecimento especial a esses tradutores:
100%
Jerry Wheeler está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
