Ir para o conteúdo principal
why! N131WU/BU/ZU RAM Replacement
O que você precisa
  1. why! N131WU/BU/ZU RAM Replacement, Remove the Screws: passo 1, imagem 1 %32
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: passo 2, imagem 1 %32 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: passo 2, imagem 2 %32 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: passo 2, imagem 3 %32
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: passo 3, imagem 1 %32 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: passo 3, imagem 2 %32 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: passo 3, imagem 3 %32
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: passo 4, imagem 1 %32 why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: passo 4, imagem 2 %32
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU/BU/ZU RAM Replacement, RAM (Memory): passo 5, imagem 1 %32 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): passo 5, imagem 2 %32 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): passo 5, imagem 3 %32
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
Conclusão
To reassemble your device, follow the instructions in reverse order.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Felice Suglia
Membro desde: 06/15/13
31.100 Reputação
Autoria de 264 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 404
