Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
In this guide you will help you to reach the screen display. It also will show you the tools that should be used in this replacement.
  1. Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
    • Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
  2. Insert a small opening tool between the rear panel and the tablet.
    • Insert a small opening tool between the rear panel and the tablet.
  3. The large opening tool is not needed any more.
    • The large opening tool is not needed any more.
  4. Move the small tool opener around the rear panel to free the 12 edges. Move the small tool opener around the rear panel to free the 12 edges.
    • Move the small tool opener around the rear panel to free the 12 edges.
  5. Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
    • Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
  6. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  7. Using a plastic Spudger remove the battery connector.
    • Using a plastic Spudger remove the battery connector.
  8. Using PH0 Phillips Driver, remove the 12 Screws in the cover.
    • Using PH0 Phillips Driver, remove the 12 Screws in the cover.
  9. Place a metal Spudger between the tablet and the back cover.
    • Place a metal Spudger between the tablet and the back cover.
  10. Move the spudger around the tablet to release the clips attached to the tablet.
    • Move the spudger around the tablet to release the clips attached to the tablet.
  11. Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
    • Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
  12. Using a metal spudger to remove the top plug connector from the motherboard.
    • Using a metal spudger to remove the top plug connector from the motherboard.
  13. Use a metal spudger to remove both screen cable connectors. Use a metal spudger to remove both screen cable connectors.
    • Use a metal spudger to remove both screen cable connectors.
  14. use openning tools to remove the motherboard.
    • use openning tools to remove the motherboard.
  15. Remove the motherboard cover to reach in the screen display.
    • Remove the motherboard cover to reach in the screen display.
Conclusão
James Napoleon
Membro desde: 05/10/2016
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-6, Cagle Fall 2016 Membro de USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 Membros
5 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 34
