Ir para o conteúdo principal
uAttend bn6000 Speaker Replacement
O que você precisa
  1. uAttend bn6000 Speaker Replacement, Disassembly: passo 1, imagem 1 %32
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Speaker Replacement: passo 2, imagem 1 %32
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Remove the two 5mm PH #1 screws from the speaker assembly, by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    • Remove the speaker assembly from the unit, by lifting the speaker up and away from the housing.
  4. uAttend bn6000 Speaker Replacement: passo 4, imagem 1 %32 uAttend bn6000 Speaker Replacement: passo 4, imagem 2 %32
    • Remove the bundled cable carefully, by prying up on it with the plastic opening tool.
    • Carefully remove speaker from unit by pulling it up and away from housing.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 107
