Ir para o conteúdo principal
Inglês
Francês
Passo 10
Use needle nose pliers to bend just the tips (approximately 2 mm) of the pins 90° up so that they are pointing the same direction as the IC face. If you bend too much of the pins, they will not be able to reach their assigned holes.
  • Use needle nose pliers to bend just the tips (approximately 2 mm) of the pins 90° up so that they are pointing the same direction as the IC face.
  • If you bend too much of the pins, they will not be able to reach their assigned holes.
Insira tradução aqui
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
