Ir para o conteúdo principal
Inglês
Francês
Traduzindo o passo 1
Passo 1
Using your fingernail, lift the flap on the ZIF connector holding the Blu-ray lens motor cable to the Blu-ray control daughterboard. Pull the ribbon cable straight away from its socket on the daughterboard.
  • Using your fingernail, lift the flap on the ZIF connector holding the Blu-ray lens motor cable to the Blu-ray control daughterboard.
  • Pull the ribbon cable straight away from its socket on the daughterboard.
En utilisant vos ongles, soulevez le rabat du connecteur ZIF qui relie le câble du moteur de la lentille du lecteur Blu-ray à la carte fille du lecteur Blu-ray.
Retirez le câble plat de sa prise sur la carte fille.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
