Introdução
The speaker is located inside the phone underneath the front cover. A T6 screwdriver is needed to access the speaker.
Peças
Não são necessárias peças.
  1. Press down the button on the back panel.
    • Press down the button on the back panel.
  2. Push the back cover upwards.
    • Push the back cover upwards.
    • Remove the back cover from the phone.
    • Press the silver button on the top of the phone.
    • Slide your thumbnail down the case seam to separate the rest of the case.
    • Gently, remove the case.
    • Careful! Do not bend the plastic tabs.
    • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
    • Remove the panel that covers the motherboard.
    • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
    • Remove the LCD screen frame.
    • Remove the motherboard.
    • Locate the speaker on the back of the removed panel.
    • Use nails to gently lift the speaker up; speaker may be slightly glued to the panel.
    • When the speaker is loose, gently lift the speaker out of the panel.
Conclusão
Job Jao
37 reputação
2 Guides authored
Equipe
Cal Poly, Team 3-27, Regan Fall 2010 Membro de Cal Poly, Team 3-27, Regan Fall 2010
CPSU-REGAN-F10S3G27
4 Membros
9 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 2,516
