Ir para o conteúdo principal
the Nokia 6230b Camera Replacement
O que você precisa
  1. the Nokia 6230b Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Press down the button on the back panel.
  2. the Nokia 6230b Camera Replacement: passo 2, imagem 1 %32 the Nokia 6230b Camera Replacement: passo 2, imagem 2 %32
    • Push the back cover upwards.
  3. the Nokia 6230b Camera Replacement: passo 3, imagem 1 %32 the Nokia 6230b Camera Replacement: passo 3, imagem 2 %32
    • Remove the back cover from the phone.
  4. the Nokia 6230b Camera Replacement, Front Cover: passo 4, imagem 1 %32
    • Press the silver button on the top of the phone.
  5. the Nokia 6230b Camera Replacement: passo 5, imagem 1 %32
    • Slide your thumbnail down the case seam to separate the rest of the case.
  6. the Nokia 6230b Camera Replacement: passo 6, imagem 1 %32
    • Gently remove the case.
    • Careful! Do not bend the plastic tabs.
  7. the Nokia 6230b Camera Replacement, Motherboard: passo 7, imagem 1 %32 the Nokia 6230b Camera Replacement, Motherboard: passo 7, imagem 2 %32
    • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  8. the Nokia 6230b Camera Replacement: passo 8, imagem 1 %32 the Nokia 6230b Camera Replacement: passo 8, imagem 2 %32
    • Remove the panel that covers the motherboard.
    • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  9. the Nokia 6230b Camera Replacement: passo 9, imagem 1 %32
    • Remove the LCD screen frame.
  10. the Nokia 6230b Camera Replacement: passo 10, imagem 1 %32
    • Remove the motherboard.
  11. the Nokia 6230b Camera Replacement, Camera: passo 11, imagem 1 %32
    • Locate the camera on the circuit board.
  12. the Nokia 6230b Camera Replacement: passo 12, imagem 1 %32
    • Place the circuit board on a firm, static free surface (no cloth/carpet).
    • NOTE: The circled alignment notch points to the left.
  13. the Nokia 6230b Camera Replacement: passo 13, imagem 1 %32
    • Pull the left holding tabs to the left.
  14. the Nokia 6230b Camera Replacement: passo 14, imagem 1 %32
    • Lift out the left side of the camera.
  15. the Nokia 6230b Camera Replacement: passo 15, imagem 1 %32
    • Pull the right holding tabs to the right.
  16. the Nokia 6230b Camera Replacement: passo 16, imagem 1 %32
    • Pull camera off of board.
Conclusão
Job Jao
Membro desde: 10/08/10
37 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-27, Regan Fall 2010 Membro de Cal Poly, Team 3-27, Regan Fall 2010
CPSU-REGAN-F10S3G27
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 1,887
