Ir para o conteúdo principal
samsung x820 LCD Replacement
O que você precisa
  1. samsung x820 LCD Replacement, LCD: passo 1, imagem 1 %32 samsung x820 LCD Replacement, LCD: passo 1, imagem 2 %32 samsung x820 LCD Replacement, LCD: passo 1, imagem 3 %32
    • samsung sgh x820
  2. samsung x820 LCD Replacement: passo 2, imagem 1 %32 samsung x820 LCD Replacement: passo 2, imagem 2 %32 samsung x820 LCD Replacement: passo 2, imagem 3 %32
    • after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
  3. samsung x820 LCD Replacement: passo 3, imagem 1 %32 samsung x820 LCD Replacement: passo 3, imagem 2 %32 samsung x820 LCD Replacement: passo 3, imagem 3 %32
    • now we have two more screws hiden
    • first time i used needle. this time i took a blade.
    • removing the last two philipps-head screws.
  4. samsung x820 LCD Replacement: passo 4, imagem 1 %32
    • be carefull. the phone is thin and you should push on two hooks two open cover case.
  5. samsung x820 LCD Replacement: passo 5, imagem 1 %32
    • now you should take of the square metal in the middle of your phone to eject display.
    • i used plastic spudger
  6. samsung x820 LCD Replacement: passo 6, imagem 1 %32
    • the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
Conclusão
3 outras pessoas executaram este guia.
sergeygraf
Membro desde: 10/24/10
161 Reputação
Autoria de 1 guia
1Comentário do guia
How can I fix with button cos it is damaged
Tangkidos Hagame - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Ao todo: 1,667
