Ir para o conteúdo principal
removing the HP Elitebook 6930p Optical Drive
O que você precisa
  1. removing the HP Elitebook 6930p Optical Drive, Battery Removal: passo 1, imagem 1 %32 removing the HP Elitebook 6930p Optical Drive, Battery Removal: passo 1, imagem 2 %32 removing the HP Elitebook 6930p Optical Drive, Battery Removal: passo 1, imagem 3 %32
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. removing the HP Elitebook 6930p Optical Drive, Optical Drive: passo 2, imagem 1 %32 removing the HP Elitebook 6930p Optical Drive, Optical Drive: passo 2, imagem 2 %32 removing the HP Elitebook 6930p Optical Drive, Optical Drive: passo 2, imagem 3 %32
    • With the bottom of the laptop facing up and the front toward you locate and loosen the M2.5×9.0 captive screw holding the optical drive into the laptop.
    • Insert a flat-bladed screwdriver or similar tool into the optical drive tab access hole and press the tab to the left to release the optical drive from the computer
    • The optical drive will unlock and pop out of the side of the laptop. You are now able to temove the optical drive from the laptop.
Conclusão
7 outras pessoas executaram este guia.
Richdave
Membro desde: 04/09/10
32.081 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 4,120
