Introdução
Step by step instructions on replacing your Nikon S3700 Lens
Ferramentas
Peças
Nenhum componente especificado.
Remove Rear casing.
Flip over rear options panel to expose LCD ZIF clamp.
Flip open the clamp of the ZIF connector and slide the ribbon cable out.
Remove the LCD.
Remove screws
Remove front housing case
Remove top cabinet part
The two areas highlighted in red have loose parts. Please keep your eyes on these parts because they can get lost easily. Once you remove the top cabinet they will most likely fall off.
Discharge the capacitor to avoid getting shocked.
Dislodge clamps on all 4 sides and remove rear metal plate.
Release lens & CCD flex from ZIF sockets. Careful not to damage ZIF sockets.
Remove lens from housing and replace. Reverse steps for re-assembly
Area highlighted in orange can be lost easily. Please keep your eyes on this part. If unit is tilted part will fall out.
