Ir para o conteúdo principal
nikon s3700 LCD Display Screen Replacement
O que você precisa
  1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: passo 1, imagem 1 %32 nikon s3700 LCD Display Screen Replacement, Removing the Screws: passo 1, imagem 2 %32 nikon s3700 LCD Display Screen Replacement, Removing the Screws: passo 1, imagem 3 %32
    • group screws according to color code.
    • Remove exterior screws
  2. nikon s3700 LCD Display Screen Replacement, Replace LCD: passo 2, imagem 1 %32 nikon s3700 LCD Display Screen Replacement, Replace LCD: passo 2, imagem 2 %32 nikon s3700 LCD Display Screen Replacement, Replace LCD: passo 2, imagem 3 %32
    • Remove Rear casing.
    • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
    • Flip over rear buttons board to expose LCD ZIF clamp.
    • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
    • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
    • Remove the LCD.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 355
