Ir para o conteúdo principal
kobo glo ereader Screen Replacement
O que você precisa
  1. kobo glo ereader Screen Replacement, Remove Back Cover: passo 1, imagem 1 %32
    • Pry the back cover off just below the grey belt between the screen and back cover. No screws. Be careful not to lose the sliding power button while you are removing the back cover.
  2. kobo glo ereader Screen Replacement, Disconnect screen cables.: passo 2, imagem 1 %32 kobo glo ereader Screen Replacement, Disconnect screen cables.: passo 2, imagem 2 %32 kobo glo ereader Screen Replacement, Disconnect screen cables.: passo 2, imagem 3 %32
    • Gently pull out these 3 cables to disconnect the screen.
  3. kobo glo ereader Screen Replacement, Remove Screen and Install new one.: passo 3, imagem 1 %32
    • Pry the screen off the middle layer; screen is also attached by adhesive tapes. You can keep them intact for the new screen. Once screen is removed. Put on the new screen and connect the cables. Then put on the back cover. Be careful not to lose the power button.
Conclusão
To install the new screen, connect the cables first and then install the screen onto the middle panel. Then install the back panel.
Ismail Esen
Membro desde: 06/08/20
97 Reputação
Autoria de 1 guia
7Comentários do guia
I appreciate that this guide exists, but could you specify which screws to remove? What size are they? And most importantly, what's the screen number? I can't find it on Amazon at all.
Thank you for your efforts.
Soma Schicksal - Responder Compartilhar
Hey, it’s been some time but as I remember you do not need to remove any screws (as per the post). You just need to unplug the screen cable.
As per the screen itself, the part might have gone from Amazon or the part number changed. Maybe Ebay or AliBaba would have it?
Ismail Esen - Responder Compartilhar
I have replaced the screen, it's now as easy as you explained. The double sided tape used was very hard to take out. But alas, it works now.
Glad that it was helpful!
is this guide for kobo glo or kobo glo hd ?
Eric Van Buggenhaut - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 102
Ao todo: 6,829
