Introdução
This guide will show you how to tear down an iyashi footrest and replace the front plastic panels.
O que você precisa
remove the 4 screws on the top and the bottom of the plastic cover .
This half front panel will need to be removed by sliding it up and off . BE CAREFUL AS THIS PANEL IS EASY TO BREAK.
Remove the 4 bolts with their metal and rubber washers.
The top left bolt may be cover by the sensor. To move the sensor , remove the 2 screws marked.
Grab the support bar and Motor track . Lift UP until clear of the plastic plate. Alternatively you can grab and lift by using the axle pins .
