Ir para o conteúdo principal
ionvac SmartClean V2 Power Button Replacement
O que você precisa
  1. ionvac SmartClean V2 Power Button Replacement, Shell (Top & Bottom): passo 1, imagem 1 %32 ionvac SmartClean V2 Power Button Replacement, Shell (Top & Bottom): passo 1, imagem 2 %32
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Power Button Replacement: passo 2, imagem 1 %32 ionvac SmartClean V2 Power Button Replacement: passo 2, imagem 2 %32 ionvac SmartClean V2 Power Button Replacement: passo 2, imagem 3 %32
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Power Button Replacement: passo 3, imagem 1 %32
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Power Button Replacement: passo 4, imagem 1 %32 ionvac SmartClean V2 Power Button Replacement: passo 4, imagem 2 %32
    • Lift the top shell off carefully.
  5. ionvac SmartClean V2 Power Button Replacement, Power Button: passo 5, imagem 1 %32
    • Flip the frame upside down so that the inside faces upwards.
    • Locate the 2 screws connecting the power button to the frame.
  6. ionvac SmartClean V2 Power Button Replacement: passo 6, imagem 1 %32
    • Unscrew the two screws connecting the power button to the top shell.
  7. ionvac SmartClean V2 Power Button Replacement: passo 7, imagem 1 %32
    • Remove the power button from the shell.
    • Position the power button correctly when reinstalling. The power icon should face the ionvac logo and the house icon should face the front of the robot vacuum.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 520
