Ir para o conteúdo principal
ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement
  1. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement, Front Wheel (Swivel Caster): passo 1, imagem 1 %32
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Flip your ionvac upside down so the wheels are pointed upwards.
  2. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: passo 2, imagem 1 %32 ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: passo 2, imagem 2 %32
    • Using your thumb and forefinger, grip the flat sides of the wheel and pull it out.
    • If the wheel is stuck, you can use a spudger to pry the caster out.
    • When reinstalling, the wheel should click into place. Before restarting the ionvac, try spinning the wheel with your finger to test its movement.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 69
