Ir para o conteúdo principal
ionvac SmartClean V2 Bumper Sensor Replacement
O que você precisa
  1. ionvac SmartClean V2 Bumper Sensor Replacement, Shell (Top & Bottom): passo 1, imagem 1 %32 ionvac SmartClean V2 Bumper Sensor Replacement, Shell (Top & Bottom): passo 1, imagem 2 %32
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Bumper Sensor Replacement: passo 2, imagem 1 %32 ionvac SmartClean V2 Bumper Sensor Replacement: passo 2, imagem 2 %32 ionvac SmartClean V2 Bumper Sensor Replacement: passo 2, imagem 3 %32
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Bumper Sensor Replacement: passo 3, imagem 1 %32
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Bumper Sensor Replacement: passo 4, imagem 1 %32 ionvac SmartClean V2 Bumper Sensor Replacement: passo 4, imagem 2 %32
    • Lift the top shell off carefully.
  5. ionvac SmartClean V2 Bumper Sensor Replacement, Bumper Sensor: passo 5, imagem 1 %32 ionvac SmartClean V2 Bumper Sensor Replacement, Bumper Sensor: passo 5, imagem 2 %32 ionvac SmartClean V2 Bumper Sensor Replacement, Bumper Sensor: passo 5, imagem 3 %32
    • Turn your ionvac so that the sensor and the metal bumper piece are facing forward.
    • Gently lift and remove the bumper for cleaning or replacement.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 96
