Ir para o conteúdo principal
ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement
O que você precisa
  1. ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Belt Clip: passo 1, imagem 1 %32 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Belt Clip: passo 1, imagem 2 %32
    • Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
  2. ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery Cover: passo 2, imagem 1 %32 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery Cover: passo 2, imagem 2 %32 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery Cover: passo 2, imagem 3 %32
    • Remove the battery cover by gently pushing inward on the arrow on the cover.
    • While maintaining pressure push the cover upward.
  3. ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery: passo 3, imagem 1 %32 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery: passo 3, imagem 2 %32
    • Remove the Battery from the socket
    • When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 357
