Introdução
Is your speaker no longer playing audio? Use this guide to repair your speaker.
O que você precisa
Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
Desoldier wires from the mother board. Use soldier iron to disconnect wires from mother board. Use tweezers to pull wires as the iron is heating.
Remove yellow tape from the speakers and use tweezers to pull speaker out.
Uma outra pessoa concluiu este guia.
