Ir para o conteúdo principal
iVIEW-754TPC Rear Panel Replacement
O que você precisa
  1. iVIEW-754TPC Rear Panel Replacement, Rear Panel: passo 1, imagem 1 %32 iVIEW-754TPC Rear Panel Replacement, Rear Panel: passo 1, imagem 2 %32 iVIEW-754TPC Rear Panel Replacement, Rear Panel: passo 1, imagem 3 %32
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
Conclusão
Robert Clark
Membro desde: 01/21/15
1.065 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 5-4, Brown Winter 2015 Membro de USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 303
