Ir para o conteúdo principal
iVIEW-754TPC Battery Replacement
O que você precisa
  1. iVIEW-754TPC Battery Replacement, Rear Panel: passo 1, imagem 1 %32 iVIEW-754TPC Battery Replacement, Rear Panel: passo 1, imagem 2 %32 iVIEW-754TPC Battery Replacement, Rear Panel: passo 1, imagem 3 %32
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Battery Replacement, Remove Battery: passo 2, imagem 1 %32 iVIEW-754TPC Battery Replacement, Remove Battery: passo 2, imagem 2 %32 iVIEW-754TPC Battery Replacement, Remove Battery: passo 2, imagem 3 %32
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC Battery Replacement, Desolder wires: passo 3, imagem 1 %32 iVIEW-754TPC Battery Replacement, Desolder wires: passo 3, imagem 2 %32 iVIEW-754TPC Battery Replacement, Desolder wires: passo 3, imagem 3 %32
    • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
    • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
    • To ease reassembly, take note of which wire goes to the negative and positive terminals.
Conclusão
3 outras pessoas executaram este guia.
calvin
Membro desde: 01/21/15
188 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 5-4, Brown Winter 2015 Membro de USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 2,543
