Ir para o conteúdo principal
iRulu AX760 Screen Display Replacement
O que você precisa
  1. iRulu AX760 Screen Display Replacement, Battery: passo 1, imagem 1 %32 iRulu AX760 Screen Display Replacement, Battery: passo 1, imagem 2 %32 iRulu AX760 Screen Display Replacement, Battery: passo 1, imagem 3 %32
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Screen Display Replacement: passo 2, imagem 1 %32
    • Open your tablet.
  3. iRulu AX760 Screen Display Replacement: passo 3, imagem 1 %32
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Screen Display Replacement: passo 4, imagem 1 %32 iRulu AX760 Screen Display Replacement: passo 4, imagem 2 %32
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. Como soldar e dessoldar contatos
  5. iRulu AX760 Screen Display Replacement: passo 5, imagem 1 %32
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Screen Display Replacement, Camera: passo 6, imagem 1 %32 iRulu AX760 Screen Display Replacement, Camera: passo 6, imagem 2 %32
    • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
  7. iRulu AX760 Screen Display Replacement: passo 7, imagem 1 %32
    • Pull the digitizer ribbon cables straight out of their sockets.
  8. iRulu AX760 Screen Display Replacement: passo 8, imagem 1 %32
    • Pull the camera out of the device.
  9. iRulu AX760 Screen Display Replacement, Motherboard: passo 9, imagem 1 %32 iRulu AX760 Screen Display Replacement, Motherboard: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • There are two thin adhesive strips under the battery that run vertically along the left and right side.
    • Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
    • Do not use metal tools, and do not bend or puncture the battery.
  10. iRulu AX760 Screen Display Replacement: passo 10, imagem 1 %32 iRulu AX760 Screen Display Replacement: passo 10, imagem 2 %32 iRulu AX760 Screen Display Replacement: passo 10, imagem 3 %32
    • WARNING: SOLDERING IRONS BECOME EXTREMELY HOT. DO NOT TOUCH
    • For information on soldering and desoldering, check this link.
    • You must desolder several sets of contacts before attempting to remove the motherboard.
    • You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
  11. iRulu AX760 Screen Display Replacement: passo 11, imagem 1 %32 iRulu AX760 Screen Display Replacement: passo 11, imagem 2 %32
    • Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
  12. iRulu AX760 Screen Display Replacement: passo 12, imagem 1 %32 iRulu AX760 Screen Display Replacement: passo 12, imagem 2 %32
    • Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
    • You will not need a metal spudger in order to re-place the motherboard
  13. iRulu AX760 Screen Display Replacement, Screen Display: passo 13, imagem 1 %32
    • Remove the plastic peel attached to the back of the screen display.
  14. iRulu AX760 Screen Display Replacement: passo 14, imagem 1 %32 iRulu AX760 Screen Display Replacement: passo 14, imagem 2 %32
    • Remove the grey wire from the back of the screen display.
  15. iRulu AX760 Screen Display Replacement: passo 15, imagem 1 %32
    • Insert the plastic spudger underneath the screen display and lift.
  16. iRulu AX760 Screen Display Replacement: passo 16, imagem 1 %32 iRulu AX760 Screen Display Replacement: passo 16, imagem 2 %32
    • Continue lifting the screen by hand and pull it out until it is completely removed.
Conclusão
Uma outra pessoa concluiu este guia.
Jamison Kritz
Membro desde: 03/20/18
245 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S6-G4, Baechle Spring 2018 Membro de IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 431
