Ir para o conteúdo principal
iRulu AX760 Battery Replacement
O que você precisa
  1. iRulu AX760 Battery Replacement, Battery: passo 1, imagem 1 %32 iRulu AX760 Battery Replacement, Battery: passo 1, imagem 2 %32 iRulu AX760 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Battery Replacement: passo 2, imagem 1 %32
    • Open your tablet.
  3. iRulu AX760 Battery Replacement: passo 3, imagem 1 %32
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Battery Replacement: passo 4, imagem 1 %32 iRulu AX760 Battery Replacement: passo 4, imagem 2 %32
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. Como soldar e dessoldar contatos
  5. iRulu AX760 Battery Replacement: passo 5, imagem 1 %32
    • Remove your old battery and replace it with the new battery.
Conclusão
Perri
Membro desde: 03/20/18
171 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S6-G4, Baechle Spring 2018 Membro de IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 249
