Ir para o conteúdo principal
iRobot Roomba i7 Front Bumper Replacement
O que você precisa
  1. iRobot Roomba i7 Front Bumper Replacement, Front Bumper: passo 1, imagem 1 %32 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: passo 1, imagem 2 %32 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: passo 1, imagem 3 %32
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, unscrew the 6.27mm screw in the center of the side brush.
    • Using a Phillips #1 screwdriver, unscrew the 5 screws surrounding the bottom cover of the Roomba
  2. iRobot Roomba i7 Front Bumper Replacement: passo 2, imagem 1 %32 iRobot Roomba i7 Front Bumper Replacement: passo 2, imagem 2 %32 iRobot Roomba i7 Front Bumper Replacement: passo 2, imagem 3 %32
    • Use the Philips #1 screw driver to remove the ten, 4.17 mm screws on the dislodged Bumper
  3. iRobot Roomba i7 Front Bumper Replacement: passo 3, imagem 1 %32 iRobot Roomba i7 Front Bumper Replacement: passo 3, imagem 2 %32
    • Once removed, readjust the bumper into its appropriate placement.
    I did all that but still have “tap on bumper” with red light..
    Guy payne - Responder
    I did all that but I still have “tap bumper message” with red light???
    how do I test sensors?
    Or change out bumper switch?
    Thanks for the guide! Could you also share how to safely disconnect the wiring harness? What are the wires for?
    zheng - Responder
    I did all but still bumper getting stuck any suggestions
    bahmad786 - Responder
Conclusão
2 comentários
My roomba seems to be blind some tomes it starts and just keeps on running into the walls over and over again sometime i rebbot it and it works and other times it doesnt work i dont know what wrong with it. Its a roomba i7+ 3 years old.
John Flannery - Responder
My Roomba will run until it hits the wall and then runs backwards. Help
beverly vernon - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 36
Últimos 30 dias: 204
Ao todo: 14,398
