Ir para o conteúdo principal
iRobot Roomba e5 Wheels Replacement
O que você precisa
  1. iRobot Roomba e5 Wheels Replacement, Side Brush: passo 1, imagem 1 %32 iRobot Roomba e5 Wheels Replacement, Side Brush: passo 1, imagem 2 %32 iRobot Roomba e5 Wheels Replacement, Side Brush: passo 1, imagem 3 %32
    • Flip the iRobot upside down
    • locate the edge sweeping brush which has a screw in the center.
    • Loosen the screw using a Phillips #1 screwdriver.
  2. iRobot Roomba e5 Wheels Replacement: passo 2, imagem 1 %32
    • Lift the side brush up from the vacuum and keep it aside.
  3. iRobot Roomba e5 Wheels Replacement, Bottom Panel: passo 3, imagem 1 %32 iRobot Roomba e5 Wheels Replacement, Bottom Panel: passo 3, imagem 2 %32 iRobot Roomba e5 Wheels Replacement, Bottom Panel: passo 3, imagem 3 %32
    • Loosen the five captive screws on the bottom of the Roomba using a Phillips #1 screwdriver.
  4. iRobot Roomba e5 Wheels Replacement: passo 4, imagem 1 %32
    • Remove the bottom panel of the Roomba.
  5. iRobot Roomba e5 Wheels Replacement, Wheels: passo 5, imagem 1 %32 iRobot Roomba e5 Wheels Replacement, Wheels: passo 5, imagem 2 %32 iRobot Roomba e5 Wheels Replacement, Wheels: passo 5, imagem 3 %32
    • Loosen the two captive screws closest to the wheel module using a Phillips #0 screwdriver.
  6. iRobot Roomba e5 Wheels Replacement: passo 6, imagem 1 %32 iRobot Roomba e5 Wheels Replacement: passo 6, imagem 2 %32 iRobot Roomba e5 Wheels Replacement: passo 6, imagem 3 %32
    • Pull the wheel module out of the Roomba, leaving an empty pocket.
    • Repeat Steps 5 and 6 for the opposite wheel.
  7. iRobot Roomba e5 Wheels Replacement: passo 7, imagem 1 %32 iRobot Roomba e5 Wheels Replacement: passo 7, imagem 2 %32 iRobot Roomba e5 Wheels Replacement: passo 7, imagem 3 %32
    • insert the new wheel module into the wheel pocket.
Conclusão
McKayla Davis
Membro desde: 03/24/22
339 Reputação
Autoria de 3 guias
Equipe
Casper College, Team 1-2, Lareau Spring 2022 Membro de Casper College, Team 1-2, Lareau Spring 2022
CASC-LAREAU-S22S1G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 50
Duração total: 1,411
