Ir para o conteúdo principal
iRobot Roomba 980 Brush Module Replacement
O que você precisa
  1. iRobot Roomba 980 Brush Module Replacement, Battery: passo 1, imagem 1 %32
    • Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
  2. iRobot Roomba 980 Brush Module Replacement: passo 2, imagem 1 %32 iRobot Roomba 980 Brush Module Replacement: passo 2, imagem 2 %32
    • Unscrew the back plate using a Phillips #1 screwdriver.
    • Carefully lift the panel up once the screws are removed.
  3. iRobot Roomba 980 Brush Module Replacement: passo 3, imagem 1 %32 iRobot Roomba 980 Brush Module Replacement: passo 3, imagem 2 %32
    • With both hands, grab the two black tabs on each end of the battery.
    • Pull the tabs upwards to remove the battery.
  4. iRobot Roomba 980 Brush Module Replacement, Brush Module: passo 4, imagem 1 %32 iRobot Roomba 980 Brush Module Replacement, Brush Module: passo 4, imagem 2 %32 iRobot Roomba 980 Brush Module Replacement, Brush Module: passo 4, imagem 3 %32
    • Press down on the button on the rear of the device.
    • Pull bin towards you to remove it.
  5. iRobot Roomba 980 Brush Module Replacement: passo 5, imagem 1 %32 iRobot Roomba 980 Brush Module Replacement: passo 5, imagem 2 %32
    • Loosen the screw holding the side brush in place.
    • The screw is attached to the side brush and does not come out completely.
    • Lift the side brush.
  6. iRobot Roomba 980 Brush Module Replacement: passo 6, imagem 1 %32 iRobot Roomba 980 Brush Module Replacement: passo 6, imagem 2 %32
    • Remove the (2) 11.5mm Phillips #1 screws holding down the bottom plate.
    • Carefully lift the bottom plate.
  7. iRobot Roomba 980 Brush Module Replacement: passo 7, imagem 1 %32
    • Remove the (4) 15.8mm Phillips #1 gold screws around the brush module.
  8. iRobot Roomba 980 Brush Module Replacement: passo 8, imagem 1 %32 iRobot Roomba 980 Brush Module Replacement: passo 8, imagem 2 %32
    • Lift the brush module carefully using both hands.
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S14-G2, Boczar Fall 2017 Membro de USF Tampa, Team S14-G2, Boczar Fall 2017
USFT-BOCZAR-F17S14G2
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 38
Ao todo: 4,990
