Ir para o conteúdo principal
iRobot Roomba 960 Side Wheels Replacement
O que você precisa
  1. iRobot Roomba 960 Side Wheels Replacement, Battery: passo 1, imagem 1 %32
    • Turn the Roomba upside down and orient it so that the wheels are facing upwards and the dustbin is furthest from you.
  2. iRobot Roomba 960 Side Wheels Replacement: passo 2, imagem 1 %32
    • With the Phillips #1 screwdriver, remove the two 11.4mm screws.
  3. iRobot Roomba 960 Side Wheels Replacement: passo 3, imagem 1 %32
    • Lift the plastic cover to access the battery.
  4. iRobot Roomba 960 Side Wheels Replacement: passo 4, imagem 1 %32 iRobot Roomba 960 Side Wheels Replacement: passo 4, imagem 2 %32 iRobot Roomba 960 Side Wheels Replacement: passo 4, imagem 3 %32
    • Using the two black flaps located at the sides of the battery, pull it towards you.
    • Carefully remove the battery.
  5. iRobot Roomba 960 Side Wheels Replacement, Side-Brush: passo 5, imagem 1 %32
    • With the Flathead 2.5mm screwdriver remove the 7.9mm screw from the side-brush.
  6. iRobot Roomba 960 Side Wheels Replacement: passo 6, imagem 1 %32
    • Pull the side-brush towards you.
    • Carefully remove the side-brush.
  7. iRobot Roomba 960 Side Wheels Replacement, Side Wheels: passo 7, imagem 1 %32 iRobot Roomba 960 Side Wheels Replacement, Side Wheels: passo 7, imagem 2 %32 iRobot Roomba 960 Side Wheels Replacement, Side Wheels: passo 7, imagem 3 %32
    • Using a Phillips #1 screwdriver, unscrew the two 11.4mm screws that hold the bottom cover.
    • Lift to remove the plastic back panel.
  8. iRobot Roomba 960 Side Wheels Replacement: passo 8, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the three gold 15.5 mm screws.
  9. iRobot Roomba 960 Side Wheels Replacement: passo 9, imagem 1 %32 iRobot Roomba 960 Side Wheels Replacement: passo 9, imagem 2 %32
    • Carefully remove the wheel.
Conclusão
Vanessa Greyson
Membro desde: 02/02/17
471 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-3, Blackwell Spring 2017 Membro de USF Tampa, Team 16-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G3
Membros da 4
Autoria de 6 guias
Um comentário
Vanessa Greyson
In steps 2, 3 and 4 you show how to remove the battery, but from steps 5-9 you show the battery installed. Is it required to remove the battery?
If this is a required safety procedure to remove the battery, I would suggest to edit the pictures in steps 5-9 showing the battery removed in those steps. If it is not required or stated in the repair instructions I would suggest to edit step 2 stating it is "Your suggestion but not necessary to remove the battery" or remove steps 2-4 & renumber the following steps.
I did something like this on another site & caught a lot of flack over it. In that one, I took pictures as I did the repair with the battery in, but forgot to mention it would be safer to remove the battery (only suggested in the instructions) to prevent damage from a short. But being a mechanic & knowing I could do the repair safely w/o removing the battery I didn't show the battery removed & someone damaged their equipment. Just a suggestion to save you from a possible big headache.
EIBBOR2654 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 58
Duração total: 6,766
