Ir para o conteúdo principal
iRobot Roomba 960 Debris Extractor Replacement
O que você precisa
  1. iRobot Roomba 960 Debris Extractor Replacement, Debris Extractor: passo 1, imagem 1 %32
    • Turn the Roomba upside down and orient it so that the wheels are facing upwards and the dustbin is furthest from you.
  2. iRobot Roomba 960 Debris Extractor Replacement: passo 2, imagem 1 %32 iRobot Roomba 960 Debris Extractor Replacement: passo 2, imagem 2 %32
    • Pinch the two yellow tabs that are located near the dustbin towards each other to open the frame.
  3. iRobot Roomba 960 Debris Extractor Replacement: passo 3, imagem 1 %32
    • Lift the frame to expose the two debris extractors.
  4. iRobot Roomba 960 Debris Extractor Replacement: passo 4, imagem 1 %32 iRobot Roomba 960 Debris Extractor Replacement: passo 4, imagem 2 %32 iRobot Roomba 960 Debris Extractor Replacement: passo 4, imagem 3 %32
    • Carefully apply pressure to one side of the first debris extractor to release it. Lift to remove.
    • Do the same to the second debris extractor.
Conclusão
Uma outra pessoa concluiu este guia.
Vanessa Greyson
Membro desde: 02/02/17
471 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 16-3, Blackwell Spring 2017 Membro de USF Tampa, Team 16-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 3,400
