Ir para o conteúdo principal
iRobot Roomba 891 Battery Replacement
O que você precisa
  1. iRobot Roomba 891 Battery Replacement, Battery: passo 1, imagem 1 %32 iRobot Roomba 891 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Battery Replacement: passo 2, imagem 1 %32
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Battery Replacement: passo 3, imagem 1 %32 iRobot Roomba 891 Battery Replacement: passo 3, imagem 2 %32 iRobot Roomba 891 Battery Replacement: passo 3, imagem 3 %32
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
Conclusão
Um comentário
justin i added a push pin to step 1
thomas Wilson - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 18
Ao todo: 884
