Ir para o conteúdo principal
iRobot Roomba 890 IR Sensor Replacement
O que você precisa
  1. iRobot Roomba 890 IR Sensor Replacement, IR sensor: passo 1, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
    • Remove the battery cover.
  2. iRobot Roomba 890 IR Sensor Replacement: passo 2, imagem 1 %32 iRobot Roomba 890 IR Sensor Replacement: passo 2, imagem 2 %32
    • Pull directly up on the grey pull-tabs to remove the battery.
  3. iRobot Roomba 890 IR Sensor Replacement: passo 3, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the one 7.7 mm screw.
    • Remove the yellow brush head.
  4. iRobot Roomba 890 IR Sensor Replacement: passo 4, imagem 1 %32 iRobot Roomba 890 IR Sensor Replacement: passo 4, imagem 2 %32 iRobot Roomba 890 IR Sensor Replacement: passo 4, imagem 3 %32
    • Use a Phillips #2 screwdriver to unscrew the two 11 mm screws.
    • Lift the baseplate up and off.
  5. iRobot Roomba 890 IR Sensor Replacement: passo 5, imagem 1 %32 iRobot Roomba 890 IR Sensor Replacement: passo 5, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the ten 9.3 mm screws.
    • Remove the bumper retainer ring.
  6. iRobot Roomba 890 IR Sensor Replacement: passo 6, imagem 1 %32 iRobot Roomba 890 IR Sensor Replacement: passo 6, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the two 7.5 mm screws holding the IR sensor in place.
  7. iRobot Roomba 890 IR Sensor Replacement: passo 7, imagem 1 %32 iRobot Roomba 890 IR Sensor Replacement: passo 7, imagem 2 %32
    • Use an iFixit opening tool to remove the outer plastic covering from the top of the Roomba.
  8. iRobot Roomba 890 IR Sensor Replacement: passo 8, imagem 1 %32 iRobot Roomba 890 IR Sensor Replacement: passo 8, imagem 2 %32 iRobot Roomba 890 IR Sensor Replacement: passo 8, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handlebar screws; then remove the handle.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift off the top plate.
  9. iRobot Roomba 890 IR Sensor Replacement: passo 9, imagem 1 %32 iRobot Roomba 890 IR Sensor Replacement: passo 9, imagem 2 %32 iRobot Roomba 890 IR Sensor Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    $3.99
    • Use a pair of angled tweezers to firmly grip the IR sensor plug, and pull it directly backwards to release it from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Caeden Foxhoven
Membro desde: 03/28/22
331 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 1,347
