Ir para o conteúdo principal
iRobot Roomba 890 Cleaning Head Replacement
O que você precisa
  1. iRobot Roomba 890 Cleaning Head Replacement, Cleaning Head: passo 1, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
    • Remove the battery cover.
  2. iRobot Roomba 890 Cleaning Head Replacement: passo 2, imagem 1 %32 iRobot Roomba 890 Cleaning Head Replacement: passo 2, imagem 2 %32
    • Remove the battery by pulling directly up on the grey pull tabs.
  3. iRobot Roomba 890 Cleaning Head Replacement: passo 3, imagem 1 %32 iRobot Roomba 890 Cleaning Head Replacement: passo 3, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the one 7.7 mm screw.
    • Remove the yellow brush head.
  4. iRobot Roomba 890 Cleaning Head Replacement: passo 4, imagem 1 %32 iRobot Roomba 890 Cleaning Head Replacement: passo 4, imagem 2 %32 iRobot Roomba 890 Cleaning Head Replacement: passo 4, imagem 3 %32
    • Lift the baseplate up and off.
  5. iRobot Roomba 890 Cleaning Head Replacement: passo 5, imagem 1 %32 iRobot Roomba 890 Cleaning Head Replacement: passo 5, imagem 2 %32
    • To remove the dust collection bin, press the release button on the top side of the Roomba and pull it straight out.
  6. iRobot Roomba 890 Cleaning Head Replacement: passo 6, imagem 1 %32 iRobot Roomba 890 Cleaning Head Replacement: passo 6, imagem 2 %32 iRobot Roomba 890 Cleaning Head Replacement: passo 6, imagem 3 %32
    • Press the bright yellow tabs inwards and lift up at the same time to expose the cleaning head.
    • Remove the main brushes by lifting them up and out of the housing.
  7. iRobot Roomba 890 Cleaning Head Replacement: passo 7, imagem 1 %32 iRobot Roomba 890 Cleaning Head Replacement: passo 7, imagem 2 %32 iRobot Roomba 890 Cleaning Head Replacement: passo 7, imagem 3 %32
    • Lift the cleaning head out of the Roomba.
Conclusão
Caeden Foxhoven
Membro desde: 03/28/22
331 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-3, Petersen Spring 2022 Membro de UMass Dartmouth, Team 1-3, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G3
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 19
Duração total: 434
