Ir para o conteúdo principal
iRobot Roomba 890 Charging Contacts Replacement
O que você precisa
  1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: passo 1, imagem 1 %32 iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: passo 1, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Charging Contacts Replacement: passo 2, imagem 1 %32
    • Place the Roomba facedown, with its bottom facing you.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
  3. iRobot Roomba 890 Charging Contacts Replacement: passo 3, imagem 1 %32
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Charging Contacts Replacement: passo 4, imagem 1 %32 iRobot Roomba 890 Charging Contacts Replacement: passo 4, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the bottom plate of the Roomba.
  5. iRobot Roomba 890 Charging Contacts Replacement: passo 5, imagem 1 %32 iRobot Roomba 890 Charging Contacts Replacement: passo 5, imagem 2 %32
    • Turn Roomba face up.
    • Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
  6. iRobot Roomba 890 Charging Contacts Replacement: passo 6, imagem 1 %32 iRobot Roomba 890 Charging Contacts Replacement: passo 6, imagem 2 %32
    • Using the opening tool, remove retaining band.
    • Use the removal tool to remove the face plate as well.
    • Pry up slowly around the edges to prevent damage to the plastic components.
  7. iRobot Roomba 890 Charging Contacts Replacement: passo 7, imagem 1 %32 iRobot Roomba 890 Charging Contacts Replacement: passo 7, imagem 2 %32 iRobot Roomba 890 Charging Contacts Replacement: passo 7, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift the top plate off.
  8. iRobot Roomba 890 Charging Contacts Replacement: passo 8, imagem 1 %32 iRobot Roomba 890 Charging Contacts Replacement: passo 8, imagem 2 %32
    • Locate the charging contact wire connection to the motherboard.
    • Release the connector.
    • Pull gently on the white plug, not the wires themselves.
  9. iRobot Roomba 890 Charging Contacts Replacement: passo 9, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  10. iRobot Roomba 890 Charging Contacts Replacement: passo 10, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
    • Remove the charging contact backings.
  11. iRobot Roomba 890 Charging Contacts Replacement: passo 11, imagem 1 %32
    • Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
    • With the charging contact dislodged, pull it through the Roomba housing.
Conclusão
Devin Steiblin
Membro desde: 03/28/22
442 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-3, Petersen Spring 2022 Membro de UMass Dartmouth, Team 1-3, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G3
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 95
Duração total: 3,709
