Ir para o conteúdo principal
iRobot Roomba 880 Battery Replacement
O que você precisa
  1. iRobot Roomba 880 Battery Replacement, Battery: passo 1, imagem 1 %32 iRobot Roomba 880 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Start with your Roomba upside down, with the wheels facing up.
    • Using a JIS driver in #1 size remove the two 15mm screws holding the battery cover in place.
  2. iRobot Roomba 880 Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery cover and place it off to the side.
  3. iRobot Roomba 880 Battery Replacement: passo 3, imagem 1 %32 iRobot Roomba 880 Battery Replacement: passo 3, imagem 2 %32
    • Remove the battery using the green tabs on either side of the battery.
Conclusão
Uma outra pessoa concluiu este guia.
Frances Belcher
Membro desde: 04/18/17
420 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G4, Banghart Spring 2017 Membro de Cal Poly, Team S17-G4, Banghart Spring 2017
CPSU-BANGHART-S17S17G4
Membros da 5
Autoria de 10 guias
2 comentários
I am not trying to be negative here, but if someone needed this guide to understand that a bad battery needed to be replaced, shouldn’t you put that they would need a new battery? According to your directions, they do not need a new battery. As a result, they are going to take out their battery, and put the old one back in. The problem remains. I have never written a guide, so maybe you can only choose parts from iFixit and that is why you did not have one listed in the parts needed, but I would have thought it would have been in the directions.
Anyhow, the guide is still appreciated… please consider this only as constructive feedback to help enhance the product.
Nathan Kramer - Responder
Not a very useful comment Nathan - the clue is in the title of the article. If someone wants to replace the battery in their smoke alarm.... it is kinda implicit that 'replacing it' doesn't mean taking the old one out and putting the same one back in.
Crazy cat lady -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 48
Duração total: 4,983
