Ir para o conteúdo principal
iRobot Roomba 870 Side Brush Motor Replacement
O que você precisa
  1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: passo 1, imagem 1 %32 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: passo 1, imagem 2 %32 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: passo 1, imagem 3 %32
    • Turn the Roomba over so that the back side is facing up.
    • Using the Phillips #00 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 870 Side Brush Motor Replacement: passo 2, imagem 1 %32 iRobot Roomba 870 Side Brush Motor Replacement: passo 2, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the four 3.5mm screws that hold down the battery panel and rear panel.
  3. iRobot Roomba 870 Side Brush Motor Replacement: passo 3, imagem 1 %32 iRobot Roomba 870 Side Brush Motor Replacement: passo 3, imagem 2 %32
    • First remove the battery panel, which is the small rectangular.
    • After removing the battery panel, remove the rear panel.
  4. iRobot Roomba 870 Side Brush Motor Replacement: passo 4, imagem 1 %32 iRobot Roomba 870 Side Brush Motor Replacement: passo 4, imagem 2 %32 iRobot Roomba 870 Side Brush Motor Replacement: passo 4, imagem 3 %32
    • Remove the three small 3.5mm screws fastened to the motor housing.
    • After removing the screws, remove the motor housing from the rest of the Roomba.
  5. iRobot Roomba 870 Side Brush Motor Replacement: passo 5, imagem 1 %32 iRobot Roomba 870 Side Brush Motor Replacement: passo 5, imagem 2 %32 iRobot Roomba 870 Side Brush Motor Replacement: passo 5, imagem 3 %32
    • Remove the 2.5mm screw in the center of the motor housing using a Tri-Wing Y1 screwdriver.
    • After removing the screw, remove the top shell casing of the motor housing. Underneath, you will see a white gear with two screws next to it.
  6. iRobot Roomba 870 Side Brush Motor Replacement: passo 6, imagem 1 %32 iRobot Roomba 870 Side Brush Motor Replacement: passo 6, imagem 2 %32 iRobot Roomba 870 Side Brush Motor Replacement: passo 6, imagem 3 %32
    • Remove the two 2.5mm screws in the inner motor housing using a Phillips #00 screwdriver.
    • After removing the two screws, the motor will slide right out the back, and it can be replaced.
Conclusão
Equipe
Cal Poly, Team S14-G3, Banghart Spring 2017 Membro de Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 37
Duração total: 3,584
