Ir para o conteúdo principal
iRobot Roomba 870 Battery Replacement
O que você precisa
  1. iRobot Roomba 870 Battery Replacement, Battery: passo 1, imagem 1 %32 iRobot Roomba 870 Battery Replacement, Battery: passo 1, imagem 2 %32
    • To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
    • Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
    • Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
  2. iRobot Roomba 870 Battery Replacement: passo 2, imagem 1 %32 iRobot Roomba 870 Battery Replacement: passo 2, imagem 2 %32 iRobot Roomba 870 Battery Replacement: passo 2, imagem 3 %32
    • Remove the loose battery cover to access the battery compartment.
    • Use the yellow tabs, located on the short ends of the battery pack, to gently pull the battery up and out of its slot.
Conclusão
Follow the steps in reverse order for reassembly.
Vitek Harvey
Membro desde: 04/26/17
149 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S14-G3, Banghart Spring 2017 Membro de Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 3,350
