Introdução
Is your Roomba not able to sense surrounding obstacles, preventing it from avoiding such barriers? If so, here is the guide to fix the problem with a simple change of the bumper sensor. All you need are the standard #0 and #1 Phillips Screwdriver heads in order to remove the two types of screws involved with this replacement.
O que você precisa
Flip the iRoomba over so that the underside is facing up.
Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
Remove the yellow side brush.
13 outras pessoas executaram este guia.
3 comentários
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
