Ir para o conteúdo principal
iRobot Roomba 870 Bumper Sensor Replacement
O que você precisa
  1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: passo 1, imagem 1 %32 iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: passo 1, imagem 2 %32
    • Flip the iRoomba over so that the underside is facing up.
    • Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
    • Remove the yellow side brush.
  2. iRobot Roomba 870  Bumper Sensor Replacement: passo 2, imagem 1 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 2, imagem 2 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 2, imagem 3 %32
    • Remove the two 3.5 mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
    • Remove the battery cover.
  3. iRobot Roomba 870  Bumper Sensor Replacement: passo 3, imagem 1 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 3, imagem 2 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 3, imagem 3 %32
    • Remove the two remaining 3.5 mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
    • Remove the entire base-plate from the bottom of the Roomba.
  4. iRobot Roomba 870  Bumper Sensor Replacement: passo 4, imagem 1 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 4, imagem 2 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 4, imagem 3 %32
    • Remove the ten 3 mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
    • Remove the bumper guard.
  5. iRobot Roomba 870  Bumper Sensor Replacement: passo 5, imagem 1 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 5, imagem 2 %32
    • Be careful when removing the bumper from the Roomba to prevent damage to the sensor wires. Remove slowly!
    • Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
  6. iRobot Roomba 870  Bumper Sensor Replacement: passo 6, imagem 1 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 6, imagem 2 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 6, imagem 3 %32
    • Remove the two 3 mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
    • Carefully detach the sensor connector from the bumper and the sensor.
  7. iRobot Roomba 870  Bumper Sensor Replacement: passo 7, imagem 1 %32 iRobot Roomba 870  Bumper Sensor Replacement: passo 7, imagem 2 %32
    • The sensor is now loose on the bumper. Be careful not to rapidly move the bumper for fear of dislodging the sensor and breaking it.
    • Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
    • Gently remove the bumper from the black infrared sensor.
Conclusão
13 outras pessoas executaram este guia.
Jacob Lindberg
Membro desde: 04/19/17
449 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S14-G3, Banghart Spring 2017 Membro de Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
Membros da 4
Autoria de 10 guias
3 comentários
Can not get to the plug-in area on the board to replace sensor this way. DOES NOT work this way.
jkeysgate - Responder
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
Reinhard Totzauer - Responder
Incomplete. This NEEDs to explain how to access the plug on the board.
Ed T. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 36
Duração total: 7,838
