Ir para o conteúdo principal
iRobot Roomba 770 Side Brush Motor Replacement
O que você precisa
  1. iRobot Roomba 770 Side Brush Motor Replacement, Battery: passo 1, imagem 1 %32 iRobot Roomba 770 Side Brush Motor Replacement, Battery: passo 1, imagem 2 %32
    • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
    • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
    • Remove the plastic plate from the battery box.
  2. iRobot Roomba 770 Side Brush Motor Replacement: passo 2, imagem 1 %32 iRobot Roomba 770 Side Brush Motor Replacement: passo 2, imagem 2 %32
    • Locate the 2 green tabs on the left and right of the big yellow battery.
    • Grab the tabs with your hands and lift straight upward.
  3. iRobot Roomba 770 Side Brush Motor Replacement, Side Brush Motor: passo 3, imagem 1 %32
    • Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
    • Remove the brush by pulling upwards.
    • Do not lean directly over the brush when attempting to remove. Removing the brush requires a firm pull and may release suddenly.
  4. iRobot Roomba 770 Side Brush Motor Replacement: passo 4, imagem 1 %32 iRobot Roomba 770 Side Brush Motor Replacement: passo 4, imagem 2 %32
    • Using the J1 Philips Screwdriver, remove the two 15.5 mm screws located on the bottom of the plate covering the bottom of the roomba.
    • Lift upwards to remove the bottom plate.
  5. iRobot Roomba 770 Side Brush Motor Replacement: passo 5, imagem 1 %32 iRobot Roomba 770 Side Brush Motor Replacement: passo 5, imagem 2 %32
    • Using the J1 Philips Screwdriver, remove the two gold 15.5 mm screws located on the blue plastic module the side brush had previously been attached too.
    • Lift the blue module upwards. The module contains the motor for the side brush.
Conclusão
Ashley Woods
Membro desde: 10/06/16
347 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-3, Livingston Fall 2016 Membro de Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 2,670
