Ir para o conteúdo principal
iRobot Roomba 770 Brush Replacement
  1. iRobot Roomba 770 Brush Replacement, Brush: passo 1, imagem 1 %32
    • Orient the roomba so it is upside down and the dust tray is closest to you.
  2. iRobot Roomba 770 Brush Replacement: passo 2, imagem 1 %32 iRobot Roomba 770 Brush Replacement: passo 2, imagem 2 %32
    • Locate the two yellow tabs on the screen that covers the brushes.
    • Push inwards on the yellow tabs while simultaneously pulling upwards on the attached grey cage.
  3. iRobot Roomba 770 Brush Replacement: passo 3, imagem 1 %32 iRobot Roomba 770 Brush Replacement: passo 3, imagem 2 %32 iRobot Roomba 770 Brush Replacement: passo 3, imagem 3 %32
    • Grab the right side of the larger brush that is located near the yellow cap. Pull upwards and to the right to remove the brush.
    • Repeat the same steps with the smaller brush.
  4. iRobot Roomba 770 Brush Replacement: passo 4, imagem 1 %32 iRobot Roomba 770 Brush Replacement: passo 4, imagem 2 %32
    • Orient the brush so the yellow tab is on the right hand side.
    • Pull the yellow tab to the right to remove.
    • Remove any debris, paying attention to the ends as well as the brush itself.
    • Replace any damaged brushes.
Conclusão
Andrew Horvath
Membro desde: 10/05/16
444 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 15-3, Livingston Fall 2016 Membro de Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
Membros da 3
Autoria de 5 guias
Um comentário
My roomba starts and moves a foot or so and then stops. I have cleaned it entirely, the battery is fine and the wheels are clean. Anyone have a suggestion
Mary Ann Dyer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 21
Duração total: 2,327
