Ir para o conteúdo principal
iRobot Roomba 690 Drive Wheels Replacement
O que você precisa
  1. iRobot Roomba 690 Drive Wheels Replacement, Spinning Brush: passo 1, imagem 1 %32
    • Place the Roomba upside down so that the wheels and brushes are facing upward.
  2. iRobot Roomba 690 Drive Wheels Replacement: passo 2, imagem 1 %32 iRobot Roomba 690 Drive Wheels Replacement: passo 2, imagem 2 %32 iRobot Roomba 690 Drive Wheels Replacement: passo 2, imagem 3 %32
    • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
    • Remove the spinning brush from the vacuum.
  3. iRobot Roomba 690 Drive Wheels Replacement, Battery: passo 3, imagem 1 %32
    • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
    • They are labeled with triangular arrows next to them on the cover.
  4. iRobot Roomba 690 Drive Wheels Replacement: passo 4, imagem 1 %32
    • Lift the bottom cover up from the rest of the Roomba.
  5. iRobot Roomba 690 Drive Wheels Replacement: passo 5, imagem 1 %32 iRobot Roomba 690 Drive Wheels Replacement: passo 5, imagem 2 %32 iRobot Roomba 690 Drive Wheels Replacement: passo 5, imagem 3 %32
    • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
  6. iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: passo 6, imagem 1 %32 iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: passo 6, imagem 2 %32
    • Each drive wheel is labeled left and right.
    • Remove three 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
    • Remove the drive wheels from the vacuum.
Conclusão
John Galvin
Membro desde: 03/23/22
584 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-1, Botvin Spring 2022 Membro de UMass Dartmouth, Team 1-1, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G1
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 481
