Ir para o conteúdo principal
Introdução
The front caster wheel of the Roomba gets dirty because it runs over all of the dirt, and debris it picks up. This guide will show you how to take the wheel out and clean it.
  1. Flip the device over onto its back. Find the side brush, and unscrew the single screw that connects to brush motor  by using the Phillips head #2 screwdriver.
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. Using a Phillips #1 screwdriver, remove the four screws on the back panel. Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  4. With the robot upside down, hold the caster wheel housing steady. Insert the plastic spudger under the wheel housing. Apply force to pry the wheel straight up. Remove the wheel housing from the robot.
    • With the robot upside down, hold the caster wheel housing steady.
    • Insert the plastic spudger under the wheel housing. Apply force to pry the wheel straight up.
    • Remove the wheel housing from the robot.
  5. Hold the wheel housing firmly in one hand. With the other hand, push the wheel up and pop it out of its slotted housing.
    • Hold the wheel housing firmly in one hand.
    • With the other hand, push the wheel up and pop it out of its slotted housing.
    • Clean the wheel with soap and water.
Conclusão
To reassemble the robot, follow these instructions in reverse order.
Rhett
Membro desde: 22-01-2015
1.088 Reputation
7 Guias de autoria
Cal Poly, Team 21-20, Maness Winter 2015 Membro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Membros
14 Guias de autoria
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 47
All Time: 1,879
