Ir para o conteúdo principal
iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal
O que você precisa
  1. iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Side Brush: passo 1, imagem 1 %32 iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Side Brush: passo 1, imagem 2 %32
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Back Panel: passo 2, imagem 1 %32 iRobot Roomba 655 Pet Series Side Brush and Back Panel Removal, Removing the Back Panel: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
Conclusão
Matt Davis
Membro desde: 01/22/15
1.642 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-20, Maness Winter 2015 Membro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 1,567
