Ir para o conteúdo principal
iRobot Roomba 655 Pet Series Side Brush Motor Replacement
O que você precisa
  1. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: passo 1, imagem 1 %32 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: passo 1, imagem 2 %32 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: passo 1, imagem 3 %32
    • First start by removing the two - 6mm screws with your Phillips head #1, that unlock the motor from your Roomba
    • Pull the brush motor out
  2. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: passo 2, imagem 1 %32 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: passo 2, imagem 2 %32 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: passo 2, imagem 3 %32
    • Next, with the same head remove the screw holding the plastic housing together
    • Carefully pry the gear box open by placing a flat head screwdriver in the slot
    • This might be difficult and require some shifting of the screwdriver
  3. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: passo 3, imagem 1 %32 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: passo 3, imagem 2 %32 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: passo 3, imagem 3 %32
    • Removing these two screws will allow you to access the motor (use the same head as before)
Conclusão
Matt Davis
Membro desde: 01/22/15
1.642 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-20, Maness Winter 2015 Membro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 1,665
