Ir para o conteúdo principal
iRobot Roomba 655 Pet Series Internal Faceplate Removal
O que você precisa
  1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: passo 1, imagem 1 %32 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: passo 1, imagem 2 %32
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Internal Faceplate Removal: passo 2, imagem 1 %32 iRobot Roomba 655 Pet Series Internal Faceplate Removal: passo 2, imagem 2 %32
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: passo 3, imagem 1 %32 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: passo 3, imagem 2 %32
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Internal Faceplate Removal: passo 4, imagem 1 %32 iRobot Roomba 655 Pet Series Internal Faceplate Removal: passo 4, imagem 2 %32 iRobot Roomba 655 Pet Series Internal Faceplate Removal: passo 4, imagem 3 %32
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: passo 5, imagem 1 %32 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: passo 5, imagem 2 %32 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: passo 5, imagem 3 %32
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
Conclusão
Rhett
Membro desde: 01/22/15
1.329 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-20, Maness Winter 2015 Membro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 763
