Ir para o conteúdo principal
iRobot Roomba 655 Pet Series Front Bumper Replacement
O que você precisa
  1. iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: passo 1, imagem 1 %32 iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: passo 1, imagem 2 %32
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  2. iRobot Roomba 655 Pet Series Front Bumper  Replacement: passo 2, imagem 1 %32 iRobot Roomba 655 Pet Series Front Bumper  Replacement: passo 2, imagem 2 %32 iRobot Roomba 655 Pet Series Front Bumper  Replacement: passo 2, imagem 3 %32
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
Conclusão
Rhett
Membro desde: 01/22/15
1.329 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-20, Maness Winter 2015 Membro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 4,321
