Ir para o conteúdo principal
iRobot Roomba 655 Pet Series Drive Wheels Replacement
O que você precisa
  1. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: passo 1, imagem 1 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: passo 1, imagem 2 %32
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: passo 2, imagem 1 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: passo 3, imagem 1 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: passo 3, imagem 2 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: passo 3, imagem 3 %32
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: passo 4, imagem 1 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: passo 4, imagem 2 %32
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
  5. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: passo 5, imagem 1 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: passo 5, imagem 2 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: passo 5, imagem 3 %32
    • Remove the three screws with your Phillips head #1, holding the drive wheels in place
    • These three screws will stay in place and won't come out of the plastic
  6. iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 6, imagem 1 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 6, imagem 2 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 6, imagem 3 %32
    • Unscrew the actual wheel from the blue plastic holder
    • Pull apart the blue holder to completely remove the wheel
  7. iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 7, imagem 1 %32 iRobot Roomba 655 Pet Series Drive Wheels Replacement: passo 7, imagem 2 %32
    • To go further into the holder to access the programming chips you can unscrew these compartments
Conclusão
Uma outra pessoa concluiu este guia.
Rhett
Membro desde: 01/22/15
1.329 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-20, Maness Winter 2015 Membro de Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 15
Duração total: 2,263
