Ir para o conteúdo principal
iRobot Roomba 595 Pet Series Main Brush Replacement
O que você precisa
  1. iRobot Roomba 595 Pet Series Main Brush Replacement, Secondary Brush: passo 1, imagem 1 %32
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Main Brush Replacement: passo 2, imagem 1 %32
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Main Brush Replacement, Main Brush: passo 3, imagem 1 %32 iRobot Roomba 595 Pet Series Main Brush Replacement, Main Brush: passo 3, imagem 2 %32
    • Remove the four 10mm screws with a Phillips #1 screwdriver. Gently lift off the external covering for the Roomba's underside.
  4. iRobot Roomba 595 Pet Series Main Brush Replacement: passo 4, imagem 1 %32 iRobot Roomba 595 Pet Series Main Brush Replacement: passo 4, imagem 2 %32 iRobot Roomba 595 Pet Series Main Brush Replacement: passo 4, imagem 3 %32
    • Press lightly on the yellow tabs and lift the cage cover containing the brush.
  5. iRobot Roomba 595 Pet Series Main Brush Replacement: passo 5, imagem 1 %32 iRobot Roomba 595 Pet Series Main Brush Replacement: passo 5, imagem 2 %32
    • Lift the brush from the right side and slide it from its container within the Roomba.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S10-G5, Thompson Fall 2017 Membro de USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 626
