Introdução
This guide is useful for replacing a dead battery or a battery that cannot be recharged through the dock for some reason. This guide is pretty simple can be done in 3 steps, and won't break anything important
O que você precisa
Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
Unscrew the four 10mm screws on the underside of the Roomba using a Phillips #1 screwdriver.
5 outras pessoas executaram este guia.
2 comentários
Pls, can i charge the roomba directly, because the base is not working??
Yes I think so, mine can
