Ir para o conteúdo principal
iRobot Roomba 595 Pet Series Battery Replacement
O que você precisa
  1. iRobot Roomba 595 Pet Series Battery Replacement, Secondary Brush: passo 1, imagem 1 %32
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Battery Replacement: passo 2, imagem 1 %32
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Battery Replacement, Battery: passo 3, imagem 1 %32
    • Unscrew the four 10mm screws on the underside of the Roomba using a Phillips #1 screwdriver.
  4. iRobot Roomba 595 Pet Series Battery Replacement: passo 4, imagem 1 %32
    • Remove the bottom frame of the device.
  5. iRobot Roomba 595 Pet Series Battery Replacement: passo 5, imagem 1 %32
    • Grab the green tape attached to the end of the battery and remove the battery from the device.
Conclusão
5 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S10-G5, Thompson Fall 2017 Membro de USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
Membros da 3
Autoria de 5 guias
2 comentários
Pls, can i charge the roomba directly, because the base is not working??
elie moussa - Responder
Yes I think so, mine can
Big builder - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 65
Duração total: 5,169
