Ir para o conteúdo principal
iRobot Roomba 595 Pet Series Side Brush Motor Replacement
O que você precisa
  1. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Secondary Brush: passo 1, imagem 1 %32
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: passo 2, imagem 1 %32
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: passo 3, imagem 1 %32 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: passo 3, imagem 2 %32
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Lift the external underside cover accordingly.
  4. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver bit to remove the three 15mm screws.
  5. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: passo 5, imagem 1 %32 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: passo 5, imagem 2 %32
    • Remove the motor from the blue casing.
Conclusão
Equipe
USF Tampa, Team S10-G5, Thompson Fall 2017 Membro de USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
Membros da 3
Autoria de 5 guias
2 comentários
I changed the motor and still does not work.
Jose - Responder
I changed the motor and still did not work.
Jose - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 733
